Beansprout said:That's one of the standard Wordpress effects (Wordpress is the blog system he's using), done by Javascript![]()
Am i missing something that's included in wordpress by default?It's in the admin panel - when you do stuff to a post, edit something, delete something, etc....the background of the status message fadessuarve said:I have used wordpress quite a lot and scowered the web for a plugins. I ain't ever seen that effect beforeAm i missing something that's included in wordpress by default?
The concept is actually known rather abstractly as "The Yellow Fade Technique" and was coined as a usability aid by 37Signals for their Basecamp web application back in 2004. The code has probably matured since then, but credit where credit is due...Beansprout said:That's one of the standard Wordpress effects (Wordpress is the blog system he's using), done by Javascript![]()
Ooh cool, thanksAl Vallario said:The concept is actually known rather abstractly as "The Yellow Fade Technique" and was coined as a usability aid by 37Signals for their Basecamp web application back in 2004. The code has probably matured since then, but credit where credit is due...
"Web Interface Design Tip: The Yellow Fade Technique" – Matthew Linderman, 19th February 2004
*av
