3 Feb 2006 at 19:17 #1 ReV0h_David ReV0h_David Associate Joined 28 Jan 2006 Posts 15 AMD FX60 with a thermaltake Tai-chi water cooled case. Will i be able to overclock much? Cheers
3 Feb 2006 at 19:39 #2 weescott weescott Soldato Joined 25 Feb 2004 Posts 9,393 Location Heckling for change Depends on the rest of your components but yes, and I would watercool the CPU and not the case.
4 Feb 2006 at 17:19 #3 ReV0h_David ReV0h_David Associate OP Joined 28 Jan 2006 Posts 15 i have the cpu attatched to the water cooling.......just waiting for my pre-order gfx card to arrive before i can get to work on it.
4 Feb 2006 at 17:34 #4 Webster Webster Associate Joined 19 Dec 2005 Posts 1,506 3Gig should be pretty easy to run 24/7
