- 15 Jan 2008
- Manchestoh
On my new system I'm planning on running a single GTX285 as the main card, and also want to use SoftTH to run triple monitors. This needs a second card but the card doesn't actually do any processing, it's purely there to output an image to the monitor so it can be a little tiddly one.
As I'm using a second card I thought I might as well use it as a dedictated physx card (it's fine to run both Physx and SoftTH off the same auxiliary card) - how powerful do these need to be to make any difference? I was looking at a Palit 512MB GeForce 9500 as they're passively cooled but have no idea if this is either useless or overkill.
Also, with massive resolutions does memory become an issue with physics processing the same as normal 3D image rendering? I can get a 1GB version of the 9500 I want for only about 3 quid more.
