- 10 Jan 2012
How quiet is the d5 on setting 1?
I want something that will be completely inaudible. Was going to passively cool my graphics card with an Arctic s1 plus but feel like doing something a bit more fun. Power supply and cpu will be passively cooled, with some inaudible case fans so worried about the pump noise standing out. I had a ddc before and that had a noticeable buzz.
Also would a single 30mm thick 120 rad be enough to cool a midrange gpu, no cpu in the loop.
. Did you do anything to dampen it at all or did you just mount it directly in the case as is?
