How should I be paying for the fitting of tyres?
26 Mar 2007
Nottinghamshire
Never gone down the mail order route before when wanting new rubber but after doing a bit of research it seems like there is quite a saving to be made...
Problem is some of the local garages are quoting £15 a corner to fit the things..is that about right?
What are you chaps paying just for the fitting process?
For 225/40/R18 wheels if it makes a difference...
edit: title is supposed to say 'How much should' :(
10~15 quid sounds about right, I doubt size makes a difference to be honest. A lot of places wont do it at all.
Have a look at blackcircles - you pay the online price and take your car to one of their partner garages for fitting
£10 - £20 each is about right for most places.
Sort of extortionate when you consider the amount of work involved.
I think £10 is the absolute max I would pay for fitting tyres.
Usually you can shop around for a better deal than online.
I pay 8quid per rim for mine for balancing/valves weights etc try to find someone who knows a tyre fitter think you could find someone! I ordered tyres once from a national chain and the guy who fitted them now just does the fitting on my internet tyres.
