Similar to what miketimbers said
Though use an adjustable male to male
Like the sort used to sli cards
Can probably find one on competition sitesYeah, I was looking for one of those on OCUK but couldn't find one other than a Phanteks one which is only 16-22mm which is real short.
Though can't mention their names obviously
Really stupid question but how do you put it together ? In my mind I cant seem to work out how I can manage to screw it all together.
I'm guessing regardless of where the ports are facing (top or battom), both radiators will be side by side.. so on the left radiator, use a 90degree rotary and the right radiator a 90degree rotary... then rather use a tube connecting both together, use one of the above m/m fittings to join both rotary fittings together, so essentially one large radiator with left and right outer ports free
