how to access wifi on my virgin superhub with new phone?
24 Oct 2005
North East
Not used wifi before, how do i use wifi on my new mobile phone galaxy ace?
Nvm found out it was really simple, now i just need to figure out how to make sure its using wifi for downloads and not my mobile providers 1gb allowance.
Android will always prioritise wifi ahead of your 3g connection provided you are in range of a wifi connection you have previously connected to.
If you want to be be very sure you can disable mobile data by long pressing the power button. If you drag down the notification bar you should be able to check that wifi is switched on. I don't have a Galaxy Ace but i do have a Samsung phone so forgive me if it's not the same for you.
One last thing, i recommend downloading 3G watchdog to monitor your data usage
