How to add exponents in Excel 2016?
Caporegime
24 Oct 2012
Yer nan's knickers
Need a quick answer hence posting here. I need to add Exponents in Excel, namely 10^2 to 10^7. Not a mathematical purpose, but the actual symbol. Anyone know how to do this?
Ta :)
Insert>Symbol>choose your symbol
It will probably set the cell to text or general format since it is a special character and therefore wont be recognised by excel as a maths formula
not in front of Excel atm, but i think there's another way...
if you mean typing 10^2 auto changes to 100 then
right click on the cell -> formatting and change the cell's type to text. then type 10^2
or, if you want 10 with a 2 superscript (like 10²) then I think you can type 102, then f2 to edit, select just the 2 and right click -> formatting -> superscript.
No need to change the cell format. You just type a ' before the text and it auto formats to text :)
so '10^2 would should in the cell as 10^2
