How to add pauses to a video
18 Feb 2010
Hi,
I recorded a video which is a voice over and a slide show using Windows Movie Maker (I exported the slide show as PNG files and dropped them in).
Now i've done it, i've played it back and find that between slides I would like to add a small pause. The narration is in lots of little bits because I didn't record it all at once. I find that if I move the audio back to cause a pause between slides, instead of moving everything else on a bit, it just overwrites the sound later on (Not good). All i'm trying to do is make it so that there is a pause between each slide, as I seem to have gone a little too fast with no pauses.
Is there an easy way to do this using windows movie maker, or any particular software that I can easily get hold of?
Thanks,
