How to apply thermal compound
25 Jun 2007
Hi,
I've totally stripped down upgraded and rebuilt a Powermac g4 MDD. I've got it all back together in a new case but before going any further I need to add some thermal compound between the CPU and heatsink. I've cleaned the top of the cpu and bottom of the heatsink to remove all the old dried up residue and have ordered some Arctic Silver 5 Thermal Compound from OC which should be here tomorrow. How do I go about applying it and how much do I need?
Please help me as I don't fancy frying my CPU after spending so much sorting the computer out.
Thanks
Hi,
Thanks
I just use my finger and wipe it on, then I just pop the chip down and clamp it. Don't believe all these sites that say you must be ever so careful.
Put a small rice grain in the middle of the Core, then take of the rice grain off and put some thermal grease on instead. Wiggle the heatsink a bit to release any air pockets and monitor temps, experiment with different amounts and methods if you have time...
Many thanks looks quite straight forward. I'll place about a grain and a half on the cpu and use the large heatsink to spread the compound and give it a slight turn and install istat pro to monitor temps. I don't suppose anyone knows the temp a G4 1Ghz CPU should run at? :confused:
Umm dont mean abit of a thread hijack, but how do you apply the Arctic MX-2 paste because i have seen no instructions of how to install it, or do i just spread it all over the chip.
Cheers
~Slash
Spreading it will your fingers will intriduce bubbles. You have to simply put the right amount of paste as a blob in the middle. The flatter the chip and HSF are, the less you need to put.
and introduce stuff off your fingers...
i like the idea of stretching cling film over your fingure and spread with that...
no mess and no air bubbles, has worked for me if that helps :-)
also, make sure its evenly spread although the minute difference that these so called guides make really isnt worth the fuss imo mate.
just use your instincts as to covering the cpu without too much excess so as not to waste the AS5 and to not create an extra barrier to heat transfer.
MODS can this be made into a sticky?? As this has to be one of the most common questions I have seen on here since I have been a member !!!
I do wonder if the " Grand Oracles" get fed up answering this one
Should you only apply the compound to the CPU or to the heatsink as well?
Some do both but i spread a thin layer on the cpu then place a drop onto the heatsink, smear it on then lightly wipe it off with kitchen towel. This makes sure to fill any imperfections on the heatsink so it has good contact with chip.
gt
i just put a line of the stuff at one end of the cpu and use an old credit card to spread it down giving the cpu a light coating of it.
Not that i want to hijack the thread but i've got a small problem with a recent cooler install.
I have a mobile sempron 754 on a matx motherboard, it was previously running at 38c using the stock amd cooler.
Yesterday i replaced the cooler with an arctic cooling silencer 64, here's where the problems started:
The cooler didn't fit on the standard bracket, so i replaced this with the one that came with the cooler. However the heatsink wasn't sitting on top of the cpu, about 1mm off due to 4 little stands on each corner of the bracket. I filed these down and now the cooler seems to sit properly, but it's now sitting at 40c idle. During these problems the CPU was sitting on a table with thermal paste on for about an hour, is it worth taking it all apart again and re-setting the cooler? i'm just not sure if it's operating properly after all the problems.
depending on what paste you used there is a curing time of up to 200hrs, so bear with it and if temps dont drop then try reseating.
Thats a good point, it's AS5 so i'll give it a chance to do it's magic. It's a difficult one as the previous 80mm cooler ran 38c at 3200rpm, whilst the new 92mm one runs 40c at 800rpm, so it might just be operating as normal.
If you mean that you applied the paste, seated it, filed it down, then seated it again an hour later....then yes. Reapply. Also sounds like you've not got a great pressure contact to start with, which is really important. People make a big deal about hwo to apply TIM, but it's the pressure that's the most important.
