I was just wondering how best to apply thermal paste?
I've read various sources that you should apply it using a credit card type spatular and spread it over the cpu.
Should this be done using only a thin layer or thinkish layer?
Also seen a few sites saying that when applying the paste you should just sqeeze a rice size amount onto the middle of the cpu then put the HSF on top and twist?
Which would be the best way?
