- 21 Jun 2004
We moved house in December. The broadband is provided by Sky who were our last provider. Since the move we have noticed the internet behaviour is worse than before. So that if you try to open a website it was b&q.com last week, it just won’t load and it is better to swap to the 1-bar 3G. Other times the websites will load with no issues, but very temperamental and find you need to manually refresh to get a page to load.
When SkyQ was installed last week the engineer started a download the engineer start doing a line check as we had downloaded less than 1% in 15 minutes (80mbps download, usually 65-70 on Speedtest). When you do a speed test it nearly always gives a high speed result consistent with what we pay. When I do a packet loss test packet loss test.com there is a 2.2% loss rate. Is that high or to be expected? Does that explain the issues we are having?
Unfortunately we can’t change the DNS server on the sky router (it’s the new one) so can’t see if it is a DNS lookup issue or not. Is there anything else I should try or further tests I can run?
Thanks for any help!
