How to Audi running lights work?
18 Oct 2002
Nottingham
Does anyone know how modern Audi running lights (DRL) work? :confused:
The previous generation was obvious as you could see the individual LEDs but the current ones make a perfect strip of even, unbroken light.
Are they still LED or is it EL wire or something special?
Will be an LED at each the end of a light pipe, the pipe defines the DRL graphic. Slightly rough surface so that it emits light along its surface unlike a fibre optic. This is how the light looks consistant unlike the older style with individual LEDs along a PCB with some sort of refraction lense to direct it forward.
