- 5 Sep 2012
So my current setup is fairly standard water blocks for CPU/GPU, 2 rads and a pump/reservoir combo. If i want to do any maintenance i can drain the system then refill via the inlet port on the Pump/Res and leave one of the top ports on the res open to bleed all the air out the system nice and simple!
I'm looking to downsize to a Meshify C and will no longer have room for my current pump/res combo so was going to mount a D5 with top just under the graphics card. The pump top has 2 inlets and 2 outlets but I'm not sure how i will bleed the system as i can't leave one of the ports open to vent any air in the system with the pump running?
My rads have the standard two ports
