As a noob to anything like case lighting etc am after a bit of advice.
Have a Lian-Li v1000 case and just bought some UV cables and a cold cathode kit as I fancied a bit of bling in my case and I was upgrading some other bits and pieces.
Where's the best place to mount the tubes to get max effect ? How many tubes will I need. The kit comes with 4 (30cm tubes) but think this is overkill really for my case.
http://www.sharkoon.com/enghtml/i_ccfl.htm#ccfl
What do people do about leaving them on. Do they stay on all the time or just when the PC is on ? I see they come with a power switch. Do I need this to be accessible then ?
Also I have seen some cool modded cases with LEDs on the mobos. Are these hard to do ?
- why if "In the United Kingdom this type of lighting is more commonly referred to as simply "UV light"" would the UV lights not work to light up internal UV components ?
