In an ensuite I'll have space to do a cupboard across the width. It'll be the best use of that space as I can maximise worktop space and area.
When the ensuite has been made I reckon wall to wall I'll have a space of 1.4m
I've done a brilliant drawing to give an idea of what mine would look like, but it'd be very similar to above, I'd just have an open shelved section on the right hand side for gubbins.
In my laymans mind I would just use timber framing with a painted moisture MDF for the entire frontage? For the shelving section I would use the same and just need to create the framing?
The top will be solid surface or perhaps a nice wood top, I haven't decided that bit yet.
