How to C+P?
Status
Not open for further replies.
Select the file you require to copy then press Shift+Delete, as long as you hold shift before you press delete you'll get a prompt box asking you to enter or browse to the location you want to copy the file to, press ok and your file will be copied to that location :)
Status
