How to calculate the volume of a paper cup?
Status
Not open for further replies.
28 Oct 2003
Worthington-on-sea
How do I calculate the volume of a paper cup, essentially a truncated cone.
Base diameter = 60mm
Top diameter = 80mm
Height = 90mm
Thanks in advance.
Quite amusing how some search results yield people using calculus and getting quite complex in their equations, and then others just giving a simple formula that works :p
pee in the cup and see how many cups of **** you can drink before you need to pee again. The average bladder can hold 400ml iirc so you should be able to figure it out that way. Theres a pretty large degree of error in this method though so you might want to repeat the experiment about 10 times to get a decent average.
Status
