How to change base/boost speed in EVGA PrecisionX 16?
25 Sep 2011
Staffordshire, UK
I have an EVGA 970 FTW (1216/1367).
I just added an EVGA 970 SC (1165/1317) (SLI).
I am trying to make the SC match the speed of the FTW but EVGA PrecisionX 16 is so confusing.
I have selected the SC at the bottom right, changed "GPU Clock Offset" to +51 MHz (which is 1216 minus 1165) and hit Apply but the white/red markers didn't move.
Confused.com.
Have you tried playing a game with them? My understanding is them markers won't move while the card is at idle as at idle most cards will turn themselves down quite a bit.
Try loading up heaven or valley benchmark and see where they go.
Hi,
the white and red marks at the top do show the basic base and boost clock of the card. As long as the digital display in the middle shows the right clockspeed it did apply. When you run SLI it is best to sync the cards, there is an option for this at the top left corner then they match in clocks and when you do some overclock it will apply on both.
