How to check a gfx card overclock?
Use the 3D slider at the right hand side,don't link the sliders together. You need to go into the settings(bottom right) then select your startup tab
I have this set to load default settings on startup & load via registry key
Then select 3D detection & Load what oc profiles you want from there. When 3D app is closed ,set it to default settings
No point running a high oc when back in 2D mode
Hope that helps & you can make sense of it
Rob
