how to check if anyone has connected to your pc?
Caporegime
1 Jun 2006
Notts
is there anyway that you can tell if someone connected to your pc without you knowing ?
ie a event log or something g#iving time and stuff details.
sharing wise? yes, under computer management. sharing and users off hand I think its called, with an option to show if anyone is connected.
Try netstat -a
You'll get a list of IP addressses.
Or in Vista/Win7, you can check the Network Resource Monitor, it'll list all connections and how much you're transmitting to them.
Or arp /a if over WiFi rather than internet.. I think. Certainly it'll show you IPs and MAC addresses on your network. You can ignore IPs labelled as static.
