how to check that volume is set max everywhere?
12 Feb 2006
Surrey
i swear my speakers used to be louder at mid setting than they currently are. i now have to set to almost fully way up for it to be what i consider a good volume for music. either i'm going death, the speakers are failing, or some where in windows something is turned down.
i've checked the volume mixer, and chrome and the master volume seems to be maxed.
i noticed the volume being lower first when i used a splitter for the aux in, as it seemed to go almost half volume, but ever since coming back to just straight in single aux, i'm still doubting the volume is it's highest possible for these speakers.
what can i do to check?
I was going to say have you checked the silly windows sound enhancements are all disabled
bass boost, virtual, loudness equalization
these can mess-with/corrupt the output sound ?
BUT
not sure what you meant by splitter .. you are using an analogue input to the PC too ?
this is the splitter i used before. i had a chromecast audio go into the speakers, as well as the pc which was connected by an aux cord. now i've removed the splitter and i've just the aux straight from pc box to speakers.
how would i check the bass boost, loudness etc?
if you genuinely meant combining two outputs via splitter that is I suspect bad ..
quick google via arts technica ... someone explained, better than I can, why.
check the sources independantly - from what you say neither works correctly now.
edit : ...maybe @lucid , or @Rroff have practical experience
No. No. NO!
You cannot use a "splitter" ("wye") cable to mix two outputs together.
You would be connecting each output to the other output as well as to the input. Line level outputs are on the order of 100 ohms or less; they are designed to work into inputs of 10K or so. Each output will therefore be working into an impedance at least 100x lower than it is designed for. Each output will short out - or nearly so - the other.
See: "Why Not Wye?" - Rane Audio:
Quote:
Outputs are low impedance and must only be connected to high impedance inputs -- never, never tie two outputs directly together -- never. If you do, then each output tries to drive the very low impedance of the other, forcing both outputs into current-limit and possible damage. As a minimum, severe signal loss results.
You know better.
Sometimes issues present in our audio drivers & audio system. So try to install the audio driver again. If it doesn't work then use 3rd party software. I already installed 3rd party software (free of cost) and increase my system volume.
