how to chnge permissions if the actual hard drive is set to read only
28 Oct 2002
or, how do i turn off the read only attribute of my (non boot) hard drive so that i can delete files?
thanks
diss
edit - there is nothing in properties - i am using ubuntu 7.04
umount /dev/hdx, then mount it without read only.
hi all
yes its an NTFS drive
Dj_Jestar - how do i mount without read only? they way i mount is just by double clicking them in the file manager - what terminal command would i use?
many thanks
diss
hi again
thanks firebarUK
i have NTFS-3g support and can read and write to my vista partition fine
its just i have 2 old winXP drives as storage devices and i can't access them because they are read only
i don't seem to have any GUI option to get rid of the read only hence wondering what the terminal command might be
hmmmm - unless of course the NTFS-3g can't see my 2 other drives because i put them in after installin it? gettin out of my depth here :(
any suggestions welcome
many thanks
diss
Hey guys thanks, that's a useful tip.
NTFS-3G is preinstalled with the new Ubuntu 7.10 but the gui config for it: ntfsconfig needs to be installed from synaptic. Then found under system tools in the main menu.
sorted it :)
there is a ntfs-config tool that detected these additional drives when i opened it - so all seems ok
cheers guys
diss
