- 30 Nov 2012
I just bought a second hand noctua D14 and god is it huge, I don't think the make of heat sink really affects stuff but I have been reading and it seems different material prefer different cleaning methods.
The only thing is it need a clean, but is not just dust is kind of greasy, so I was thinking of hand washing it in plain tap water and leaving it to dry. That should be fine. Although I am worried that some water could get stuck some where e.g. between the heat pipes and the base, is this a worry or am I just paranoid.
Also I noticed the base (contact area) had some slight marks on it where it had been pushed into the CPU, as they are slight (cant feel them when I run my finger over them) will it affect the performance and is it worth trying to polish them out. It says the material is copper/aluminum (nickle-plating), is the base nickle coated and if so if I try to remove these scratches will I remove the plating and therefor reduce its performance and remove any benefit from removing the scratch.
