How to clean heatsink and cpu?
There is cleaning Fluid made by Akasa which is excellent.
I just wipe down with a cloth or some baby wipes and it does the trick if i havent got none of that handy. Just
make sure there isnt any Hair and its fine. :D
Lint free cloth or tissue paper is what I use give both the CPU & Heatsink a good 5 min rub each, done the trick for me all the time in the past.
For the heatsink i use a compressed air dusters which removes virtually all dust frm the heatsink and also uses no chemicals wich get transferred onto the heatsink itself, as for the CPU i suggest a citrus based cleaner widely available from most computer shops
try: No competitors
I clean my heatsink and CPU in the following fashion:
  • Clean again with Akasa TIM
  • Clean both with meths, using a bit of loo roll
  • Dry h/sink with loo roll
