How to compress AVI?
Guv
Guv
24 Oct 2002
Warwickshire
I've just taken a 30min video off a video camera and it's come out as an AVI file at 15gb!
Is there some software that can make the file size smaller?
AVI is just a container, you'll have to use compression software to shrink it down. You've probably got windows moviemaker installed which you could try playing with :)
install xvid koepi
install virtualdub
install lame acm
open in virtualdub
set audio compression to mp3 192kbs 48000
set video compression to xvid 1200kbs
press F7
