How to Connect Aego M to 360 + PC?
3 Jul 2005
Im just wondering, how do i connect my aego m speakers to my xbox 360 and my computer?
also, what is the yellow connector at the back of the speakers for, and what does the "center input on/off" switch mean?
Cheers
I'm not sure about the 360 but you all you need is to use the provided cable (a 2 coloured cable merging to 1 3.5mm jack) to connect the back (according to the colour) and the 3.5mm jack into the audio output of the pc - either in the front or the back of the CPU, there should be a green 3.5mm female.
If it's to connect both a 360 and PC, I'm sure you'll need a switch box.
There's a yellow connector at the back of the speakers??
Oh that!
Well, don't need to worry about it, you can actually set the aego m to 3.1 but errm... it'll be odd? lus, you'll need a third speaker - when you set that up, turn "Centre" on and you'll get 3.1 set up.
If it is just an unpowered switchbox it should have no real impact on the sound at all. So long as it has the right connections, i'd go for it :)
Audio switch box. A well known electronics retailer sells one for £10, or the South American rainforest site has a 3 way audio selector for £5. Both will do the job fine, you may need extra cables, as both units use RCA connectors.
If your using the component cable from the 360 then run a set of RCA to minijack cable from the audio of the component cable into the audio in on the sub and plug in/out as needed. Plug into the PC with another same cable into the RCAs on the back of the sub
