How to connect external usb to internal usb ?
10 May 2004
South UK
Hey everyone,
How could I connect an external USB socket to an internal motherboard USB socket? Is there a cable available with internal connections at one end and external at the other?
Regards, Mark.
Do you mean USB headers on the motherboard?? Then yes there are cables available which can connect to the USB headers and provide additional USB ports via PCI slot. Also if your case has front USB ports then these can also be connected to the headers.
