Best fan config and connections
Hello,
I'm about to start a new build after many years of buying off the shelf and I'm a bit rusty. In the past I've just plugged fans in without thinking so want to make sure I get things spot on this time.
I have the H80 cpu cooler and three additional 120mm 3-pin fans going in to a CM690 II. Mobo is GB Z68XP-UD3P.
If I connect the fans to the headers on the mobo will I be able to control them or can you only do this with 4-pin fans?
Is it best to connect the fans to the PSU and have them running @100% all the time?
My fan config will be -
120mm Front (srandard case fan) IN
120mm Bottom IN
120mm Side IN
H80 x 2 120mm IN
120mm Top OUT
Is this a good config or is there a better one?
Thanks in advance.
Hello,
120mm Bottom IN
120mm Side IN
H80 x 2 120mm IN
120mm Top OUT
Thanks in advance.
