How to connect up HDMI.
Yup just the adaptor, although if you don't intend to run sound through the monitor (or if it doesn't have speakers) then you may as well just connect it via DVI.
Whats the point, your connection will still be DVI, just use a DVI cable, if it was a HDMI connection on the monitor yes, have just googled ££2.72 for a 2m one.
Thats what i was thinking, but if i got a Blu ray for my PC and just left it connected through DVI would it play in 1080p?
Ah right, i thought it had to be connected with a HDMI lead for it to use 1080p.
Cheers guys!;)
