How to cook a roast joint?
17 Jun 2012
Have asked this elsewhere and have been given different answers. Issue is, do you add water to the roast?
Some say yes others some no. I think you will dry out roast if no water, I don't know then. Tips?
We could do with knowing the meat and the cut of it. How much fat is there?
Generally speaking you probably don't want to add water but there are some cuts that will need it.
How do you plan on cooking it?
That's really helpful for the OP :rolleyes:
Would "no and yes" have been more accurate for you? The answer I gave was the best I could from the original post.
jsmoke, unfortunately it isn't a straight forward solution, for example you can cook Pork belly quite happily with or without some water in the tray depending on how you want it to turn out. You can also put some water in at different points in the cooking stage. If you want to be like Heston you can cook a whole joint in water (in a plastic bag) but I probably wouldn't recommend it as a starting point.
What animal is it, cow or guinea pig?
Which part of the animal is it; tongue, arse or somewhere inbetween?
What is your desired result, still mooing or falling apart when you look at it?
In his defence the OP isn't exactly helpful in the first instance! :D
I think a better response is to point this out and ask leading questions rather than just answer with something flippant and wait for the resulting annoyed response before being more helpful though. As has been said before, this isn't GD.
