- 10 Sep 2013
Is it easy to set up a crossfire setup, do I need to download anything?
Do you have on card already or are you getting 2 new ones?
use 1 Bridge to connect the cards only, I see a lot of people using 2, but this is wrong.
1. Make sure the crossfire bridge is installed.
2. Download and install the latest 13.10 Beta drivers.
3. Open up CCC and check crossfire is enabled.
Play.
I use two. It looks better.
It has no negative effect at all and the 2nd bridge is ignored by the cards. Its only there for tri-fire and above.
