How to daisy chain Router/Switches ?
21 Oct 2002
30 miles north of London
Hi,
Can anybody point me at an idiots guide to daisy-chaining router/switches ??
I want to use my new DIR-655 as a 'master' with my newer fast stuff and my old airstation g54 as a 'slave' with my older stuff.
The DIR-655 will be connected to my Virgin-cable box and the Airstation will be plugged into the DIR-655.
Both the Airstation and the DIR-655 will have a NAS & Wireless connections active (airstation controlling old printer & Wi :()
Any info/tips would be appreciated
Brian
Is there any reason why you need two wireless connections? cant you run everything off just the one?
According to the DIR-655 data if you run 11g / WEP then the whole network runs at 11g, my Wi & Network printer use 11g/ WEP :(.
At least thats the way I read it :o
Just connect them any way you like, there's no such thing as master or slave.
I know :)
The proposed network is :-
DIR-655 connected to internet
11n for laptop / Kids game PC
1GB wired for Main PC & NAS
Airstation (connected by wire to DIR-655)
11g for Printer / Wi / DS
10/100 for old slow NAS and VOIP telephone
I can get it connected such that everything can see the Internet but the drives etc on the Airstation don't work (aren't vsible).
I need guidance on getting the Airstation to have the same IP numbering as the DIR-655 (at least I think so :confused:)
Read the manual, or poke around in the web interface for the option to change the Airstation's IP, and connect the two routers together by their switch ports.
I thought I'd connect the WAN port of the Airstation to a switch port on the DIR-655 :confused: , or is that the bit I've been missing :D
If you use the WAN port, you wind up with the devices attached to the Airstation getting NATed again, resulting in the problem you're having.
where's the slap-myself-on-the-head smiley when you need it :D
Just tried it & the VOIP phone works , just to do the rest now
Thanks
