Permabanned
- 3 Jan 2015
as some will know i have a gtx 750 non ti and when im not on xbox(360) i have it connected to a 22" led hd monitor(benq GL2250)..
the max resolution is 1920x1080, but when i got xbox on(like now) im using a no brand 17" lcd which has a max of 1600x1200(connected to onbard while benq connected to gpu for dual mode, basically i switch modes on BQ for pc/xbox), but with the extended screen i could only get it to work on 1280x768(1024 recommended)..
now, i am in the process of looking up a new monitor to replace the no brand and this time connect to 750 via dvi like the benq is rather than vga on mobo(or maybe use mobo hdmi port), but since its going to be mainly used for pc as i rarely use both screens for one device i will want it to be the best it can be for a low price..
but i am unsure if my GPU can better 1920x1080 which is where the question comes from?
