How to diagnose possible hardware issue (wireless card)
25 Aug 2010
So took my laptop out my bag tonight (hp probook 4530 on windows 10) and the WiFi had stopped working, it eventually switched back on but just a red dot on the icon and it won't see any WiFi networks (on my phone in the house so I know the WiFi is on and working...)
Gone through some vague troubleshooting found online, reinstalled the device, restarted it in bios etc but nothing works.
Just wondering if there's a way I can check if it's hardware fault or not
Cheers
generally if its a hardware fault it won't even show in your device manager, check if it appears there....
if it does appear, then i would assume you have the wrong driver (if you haven't dropped/damaged it) perhaps you need to wipe the old drivers completely and do a fresh install (reinstalling windows always helps also if you have the time and really can't fix it etc).
Note: from my experience wifi drivers are always a pain in the ass XD
cheers for that - ended up sorting itself out - plugged in wired connection in the office and the next windows update seemed to sort it, annoying when I don't know what the issue was in case it comes back!
