How to dim a power LED
17 Dec 2004
I have the Cooltek W2 case and I haven't got the power LED connected at the moment but I would like it connected. But with it being in my bedroom and having the pc on a lot when Im sleeping, the LED is just too bright.
I had one idea, would a 7V Voltage Reduction fan cable make the LED any dimmer?
I bought some 'LightDims' for my room. Little stick on dots which go over LED's and come in different sizes. They do different colours, and have ones which block out 80% of the light or completely opaque. £5 from the rainforest, bit much for what it is, but i couldn't be bothered to mess about.
I'm using the 80% ones and they're awesome.
A resistor will do it. There'll be two wires going to the led. Break one of the wires and shove said resistor between the two broken ends. Solder or twist and bung some tape on.
Choice of resistor depends how dim you want it. 1k would be my choice as a starting point. Or use a 5k trimmer potentiometer and dial in your preferred illumination.
Alternatively you could make an extension cable and wire in the resistor/potentiometer so as not to break your original cable.
With mine I also changed the led colour and when doing so added a small resistor at that point. Thr original blue was enough to light my room. Now it is just indicator bright. Subtle.
That might be hard to do with my case because the LED shines around the power button, so I would need it stuck onto the LED. I haven't even bothered connecting mine up at all yet, because from pics in reviews the LED lights everything up, not just the power button......
If you buy 1k, a pack of 100 for £1 then if they are too bright with 1 you can put 2 in series for 2k, if they are too dim with 1 then you can put 2 in parallel for 500ohm, or multiples.
If you could measure the current and voltage with a multimeter you could determine this before buying.
So I will order the 1k ones and then you guys can let me know what resistor I need depending on the brightness the 1k gives out.
I am guessing its ok to cut the metal wires to make them shorter?
So if I connect the resistors on the + lead, it will dim the LED's and if I put them on the - lead it will brighten then LED's. Is that what you mean by saying "series" and "parallel"? Sorry this is all new to me.
No, in series means you cut one of the wires going into the led and put the resistor between the 2 cut ends.
Parallel means you fit the resister across the + and - wires.
http://www.bbc.co.uk/bitesize/ks3/s...y_forces/electric_current_voltage/revision/4/ :)
No. When I say putting in series and parallel I mean with each other not as to create a new load.
Start by breaking the wire, any will do. Then strip both ends and put one resistor and attach a stripped end to each leg of the resistor. Now the current must pass through the resistor before it gets to your LEDs.
If the LEDs are too dim then get another resistor and sit it on top of the first and attach it by twisting legs over the first. The current is now shared across two resistors and the resistance is lower, therefore a brighter led results.
For a dimmer led you'd have two resistors in a row so the current must pass first through one resistor and then the other. This doubles the resistance and makes the led dimmer. Technically you could out them anywhere in the circuit and break multiple points but that's just messy.
Hope that helps.
Are you using the built in fan controller? If not you have a nice switchable 5v power right there and waiting. Would give you the option of 5v/12v or off
Hope that helps.
Yeah that makes sense, thanks.
I am using the fan controller and its 7volt and 12volt, but I have got a 7V Voltage Reduction fan cable that I could try?
