if you were to set a cpu core voltage to say 1.3 rather than Auto, how would you get the voltage to drop back to circa 1.0 on idle at 1600mhz?
enable speedstep and c1e, that way when the cpu is being used it will drive upto your specified volts and clock then throttle back when not in use
