How to easily backup 125GB on to DVDs?
23 Nov 2004
The Place To Be
I'm heading off to uni on Fri. I have a 125GB music collection and have not backed it up. Funnily enough, I would be more upset if my music collection was stolen than the laptop itself. iTunes does not support my laptop's BR drive and I can't use that :(
Which programme will let me backup my music folder accross however many DVDs required?
Many thanks!
Personally I would buy a external HD can be had for around £40-50 certainly a lot easer than backing up to over 30 dvds. Software wise however I beleave Nero lets you pan disks or even windows backup selecting to backup a folder can span it over multiple cds/dvds
or if you have a spare internal hard drive, just buy one of those £20 odd external cases so you can connect it up by USB and just dump what yer need on it.
I have one, but the music is on that anyway! and i'm taking that to uni. If it got stolen I would cry like a little girl.
I've backed GB into DVD-R's. Fine if you just use Nero and backup directory by directory, bit slow bit you'll get through it eventually. Although if you have files bigger than 4GB you'll need to split with rar. I guess then proper burning sw with spanning would come in handy.
So the music collection is on an external HD atm then?
Why dont you get a cheap external HD encloser and pop an internal HD in there and transfer the music to the new HD?
Backing it all up on DVD's would take forever.
+1 for get another HDD and backup to that.
Yes, you can use DVDs but it'll be awful tedious and awful tedious != regular backups.
You could just use nero?
Call it 30 DVDs to make the numbers easier. Seven, maybe eight minutes a go in a 16x burner, that's only 3.5 to 4 hours. An evening but hardly forever.
If they're that important then you'll need to do a verify which will add around another 8 hours to the above.
I remember around 2001 or so when I knew my main storage hd was on the way out (back in the days of the IBM Deathstar...) I backed up a lot of mp3 collection onto CD-R, never mind DVD-R. Was only 14 discs, however 16x DVD is a fair bit faster than 32x CD.
