How to enable crossfire X
16 Dec 2009
Bolton
This might sound stupid but I have the new 10.6 Drivers and I cant find where to enable crossfire. People said it was in the advanced view but I cant even find the advanced view button. xD
Should be enabled by default, basically open CCC and goto the 3D section, make sure Catalyst AI is enabled (either standard or advanced) and that will be crossfire enabled.
Can check its working by opening GPU-Z, near the bottom it will say Crossfire: Enabled (2 GPU's) or something similar
Says disabled in GPU-Z
you may need a roboot once or twice for it to take effect
i did with mine
in the xfire tab in ccc
Should look like this
You only get that crossfireX option in the CCC when you have more than one ati card so if you dont see it you have a single card or your second card is not being detection for some reason.
A few people are reporting various cf problems with the 10.6's you maybe better to use the 10.5 hotfix drivers and crossfire application profiles.
Didnt load for me before, strange.
Have you checked the 3D settings i mentioned? Does each card work by themselves if you install them one by one?
Did you upgrade the drivers or are they a fresh install? If upgrading did you remove the original ones or install over the top? What driver version are you using?
only detects one card Its a fresh driver install I'm gona try switching the cards around and playing around with the bridge connectors.
I bet anymoney he has not installed the crossfire bridge cable .
to connect both cards. could be a faulty cable if connected. use the other 1.
I did install the cable.
Anyway I just took both cards out and swapped them around it seemed to work I have Crossfire now. :P
