How to enable HDCP on x1650 pro
4 May 2007
West Midlands
I was trying to watch a hd-dvd last night on my computer using winDVD 8 ultra but it says I require HDCP, I'm pretty sure my monitor allows it (samsung pebble 20" connected via dvi) but how do I enable on my graphics card?
Some graphics card comes with it, some don't, don't think you can just enable it. Not sure whether the x1000 comes with it sorry, although most ATI cards from the 2000 series and up do
** AMD’s ATI Radeon™ X and Radeon™ 9550 series of GPUs are capable of processing HDCP signals ("HDCP ready"), however not all ATI Radeon graphics cards are HDCP ready. Please check the applicable ATI Radeon graphics card specification to determine if a particular ATI Radeon graphics card is HDCP ready. Some third parties manufacture graphics cards containing ATI Radeon GPUs -- you can inquire of them which models, if any, are HDCP ready. In addition, playing HDCP content requires additional HDCP ready components, including but not limited to an HDCP ready monitor, disc drive, multimedia application and computer operating system.
Some 1650Pros have it and some dont, you'll have to check the specs of card on the manufactors website.
But if its there, you dotn have to enable it. (so i guess you're one doesnt support it)
