How to enable overclocked bundle?
Hit del during boot, pick the overclocked profile. Would help if you had bothered to say which motherboard this is.
Sorry Gigabyte GA-P55-UD5.
I did see the option the first time I booted the pc but now I just get the Gigabyte intro page and some options at the bottom but nothing that says profiles.
Del of course take me into the bios but there nothing listed as profile.
Load optomised defaults
Load fail safe
Load CMOS from Bios
Those are the only load options.
As long as you don't flash the bios to a new version and don't intentionally overwrite the profiles with anything you'll be fine. The worst thing you're likely to achieve by changing things is the computer refusing to post (turn on and write things on the screen), which is solved by resetting the cmos. Either using a button if you've got one, or by moving a jumper next to the battery for 10s or so.
