- 9 Sep 2007
have done a search but can not find ,please advice how to enable shaders overclocking in rivatuner when using windows xp ,thanks
thanks but I don't have that box to tick !
Its something to do with using xp it has to be manual enabled in power uses somewhere by entering a 1
Yeah 2.06 someone described how to do it on this site a couple of months ago but can not find it !
Weird; never had to anything with mine when I installed Riva, it was just there...
I read the guides on how to do this in XP and I couldn't get it to work either. The guides I read were full of cheese!
If no one figures it out and posts tonight I'll have another go at it tomorrow.
Edit: This is the guide I tried
you using xp though ?
Yep, XP_SP2
strange as according to this its disabled fro xp users
http://www.guru3d.com/newsitem.php?id=5958
anyway its sorted now![]()
That link shows Rivatuner 2.05, maybe 2.06 fixed it by default.
