Otacon said:You shouldnt be dumping things in System32 for that. Create your own folder somewhere (My Docs\My apps or something) and add that folder to the PATH environment variable (Conrol Panel > System > Advanced > Environment Variables).
Same result and keeps you out of system directories.
Better than an environment variable? How so.bledd. said:the best place to put them is here
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths
Overwrite the Winlogon\Shell registry value with cmd.exe (instead of exporer.exe)... if you really wanted tomanveruppd said:That IS handy! Now... is there any way I can run Windows purely from the command prompt and not have the desktop and explorer.exe load up?![]()
