How to escape a rear strangle?
  • Thread starter Thread starter Deleted member 61728
  • Start date Start date
Whop your wanger out and start feeding the ducks whilst whispering loudly "Tighter, Tighter". He'll think you're such a freak he'll loose his grip for a few seconds giving you enough time to get loose and then pistol whip him with your todger. Works every time.
If someone gets you in a strangle whereby it a single arm wrapped tightly around the front of your neck or rope/belt etc from behind what are your options to survive if any ?
Very easy to get out of in the Dojo when it isn't for real however in UFC the same move will virtually always result in a tapout.
Going to ground in a ring is fine in your jim jams. Do it in the street and someone will take a running start before sinking their boot into the back of your skull via the front of your skull. Been there. Suffered that. Last place I want to be out on the street is on the ground.
You just drop to the floor, anyone can do it and its the only viable way out for either sex of any build.
Same as if anyone grabs your arm, you break to the thumbs, doesnt matter how strong they are, they wont be able to keep hold of you.
If someone grabs your clothes at the front, you break with your elbows down on top of theirs then strike as they come forward.
On topic, if you're an average joe who doesn't fight, and another guy has you in a rear naked choke on the street, and you cannot get him in the danglies, or gouge his eyes, your only option is to fap furiously, maybe he will be grossed out and let you go. Otherwise you're out mate.
