How to find IP,Gateway and DNS settings??
29 Aug 2011
UK
Hey guys Im trying to setup a device that needs the internet setting above I tried to put them in through going to the router settings. but its not working am doing something wrong??
many thanks
here are the settings:
ADSL Port
IP Address 94.0.2.93
Network Type MER
IP Subnet Mask 255.255.255.255
Gateway IP Address 94.0.2.126
Domain Name Server 90.207.238.97 90.207.238.99
LAN Port
IP Address 192.168.0.1
DHCP On
IP Subnet Mask 255.255.255.0
Does the device not support DHCP?
IP is the IP of the device you are setting up, pick a free one from your 192.168.0.0 range. For example - 192.168.0.2 It must not be in use and preferably outside of your DHCP range. You can use anything between 192.168.0.2 > 192.168.0.254 that is free.
Gateway is your router IP - 192.168.0.1
DNS is your Domain Name Resolution server - You can use your router 192.168.0.1, your ISPs DNS servers, or an open one like Google 8.8.8.8.
Brilliant thanks dude, got it all working now :) much appreciated.
