how to fix broken pci slot hinge
17 May 2013
Finland
Well somehow i managed to break my crossairs v-z pcie hinge when prying off a gpu.
does anyone know if its possible to swap an unused pcie slot hinge to the broken one ?
or am i a-okay without it as there are two screws holding down the gpu and the card is obviously firmly pressed to the bottom of the slot?
picture of the part that is broken--->http://s1278.photobucket.com/user/M...[user]=135755951&filters[recent]=1&sort=1&o=0
anychance you can glue it back? using some strong superglue?
if not it should be fine aslong as its screwed/clamped into the case at the other end
thanks for the reply, i dont think i can glue it back, there is a hig probability that it wont move at all afterwards.
