How to fix this problem ?
20 Nov 2006
Starting windows up on one of the work computers and it says;
Windows cannot startup, this following file is missing or corrupt.
C:\windows\system32\config\system
How to i fix this, the only option i have from booting from the install disc is to go into the recovery console.
Help please !
Its windows XP pro.
did you run it with the /f switch? Did it repair the errors or did it say they are unrecoverble?
Try a full Windows repair (the one through the installation screen). Although, as Sp00n said; it does sound as if your hard-drive is dying. There is also the possibility that your RAM might be slightly faulty causing corruption and errors on your hard-drive.
