A few years ago, I had a repairman come fix my old Hotpoint washer dryer. A few months later, the dryer still worked, i.e motor works and drum rotates but no heat output, completely cold. I've never bothered to try and fix it, I just dry my clothes near radiators. But I wouldn't mind trying to fix it and it looks like it might not be too difficult, I'm not sure.
Google says "Open your cabinet and locate the heating element so that you can test it. Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it."
Another source says "With an electric clothes dryer, no heat often means that the circuit breaker or fuse that controls the power has blown; reset or replace it. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both. In some cases, an electric dryer doesn’t work because of a broken heating element—call a repairman for this fix."
I've no idea how I would test or replace a heating element and hopefully it's not that. I might at least be able to replace fuses if not an element. Any idea if it's easy to access and replace a fuse, where I could get one and if they're cheap?
