how to flash an nvidia bios with no floppy?
Caporegime
18 Oct 2002
block 16, cell 12
hi all, i want to flash my 7800GTX to the latest bios revision, unfortunately i dont have a floppy... and my cd making skills are small.
can anyone help me work out the easiest (it has to be easy peasy lol) way for me to create a bootable cd that i can flash my bios with?
thankss
Just make a bootable CD with nvflash or whatever program you use now and the bios on.
Tim said:
Wonder if you could use Leadteks Winfox Windows flasher? Is the card Leadtek by any chance?
Don't use Leadteks Winfox Windows flasher if your thinking of running SLI with them sometime....(It somehow disables the SLI support in the cards)
Get a floppy drive for about a fiver and use NiBiTor 2.6
Here's a guide to making a bootable CD in Nero 6, Nero 7 should be the same procedure.
EDIT: Here's a better way.
http://www.thetechguide.com/howto/winmebootcd.html
Grab the image file from that site. (put on Desktop so it's easy to find)
Open Nero, or other burning program (preferrably NOT the Windows XP burning program - I'll use steps in Nero as the example).
Create a new CD. Select in the list - CD-ROM (boot). Click the box to point Nero to that image file you downloaded. In the bottom section, choose in the pull down menu - Kind Of Emulation = Floppy Emulation 1.44. (you can leave 'Boot Message' and 'Load segment...' alone) In the final box, change the 1 to a 4. Click on New.
Now, in your compilation box, simply drag and drop your flash, and BIOS rom file and burn.
Set your comp's BIOS to boot from CD if you haven't already, and restart.
