I have a Toshiba laptop that's a few years old, and had to reformat it - only problem is that 38% into installin Xp on this laptop the whole thing crashed. Now when I try to reinstall Win Xp I have a problem and get a blue screen with partmgr.sys error message.
Now I would like to format this partition and maybe delete it and create it, but I can't get far now into the Windows setup due to that error message. So are there any good freeware programs that can be put on to a CD and booted from the cd drive at start up that can format and partition a hard drive that's around 15-30GB in size.
I hear GParted can do something like this, but does that have the ability to format a partition.
All help/advice is welcome.
Thank you
Thank you
